Visitor pixart_pg
Unable to generate SDF files in Plan Ahead 14.7
Design Tool : Plan Ahead 14.7
Simulator : NC SIM
We're trying to generate SDF(.sdf) and Verilog Simulation Netlist File (.v).
TCL Command : write_verilog /net/project_path/GL_TIMESIM.v -mode timesim -sdf_anno true
Results:
Tcl Console:
Warning : [Designutils 20-195] Net din has conflicting value (<N6> vs. <N12>) on different bits for attribute USER_ALIAS
Warning : [Designutils 20-195] Net din has conflicting value (<N108> vs. <N114>) on different bits for attribute USER_ALIAS
Warning : [Designutils 20-195] Net din has conflicting value (<N103> vs. <N107>) on different bits for attribute USER_ALIAS
write_verilog : Time (s) : cpu = 00:00:06 ; elapsed = 00:00:06, Memory (MB) : peak = 1285.062; gain = 0.125
Trying to search for sdf file, but can't find in project path. I expect NCSIM support the verilog simulation netlist and sdf as we did it using ISE 10.1i (previous project).
Re: Unable to generate SDF files in Plan Ahead 14.7
Hello @pixart_pg
Can you check whether the SDF file has generated in the following locations:
1. <project_location>/project.sim/sim_1/
2. present working directory i.e., pwd
As there are only warnings generated, I expect the tool to generate sdf file.
Vinay
Did you see in the log a message as " SDF Annotation successful" ? Are you running the command outside PA or from the GUI itself?
Debraj
check this related ARS
http://www.xilinx.com/support/answers/53242.html
Thanks and Regards
Balkrishan
Visitor pixart_pg
Yes. It's safely to ignore the warning but why there's no SDF file generated. From the help description, the SDF fil should be generate if you specify the -sdf_annotated true.
Visitor pixart_pg
No. I'm running this command in PA GUI's tcl console.
Visitor pixart_pg
Anyone can help for this issue?
Visitor pixart_pg
Can anyone confirm that the SDF file generation is working in Plan Ahead 14.7?
Visitor pixart_pg
Anyone can help on this issue?
Hello @pixart_pg
I followed below steps in planAhead to generate the sdf file:
  1. Open project and ran implementation
  2. Open the implemented design
  3. Ran the tcl command: write_verilog /path/to/file/timesim.v -mode timing -sdf_anno true -sdf_file bft_tb_time_impl.sdf
  4. Ran timing simulation and I observed bft_tb_time_impl.sdf file in project_name.sim/sim_1/impl/timing folder.
Vinay
