jvogesnw
Unable to simulate Logic Simulation Tutorial
I'm following the Logic Simulation Tutorial from DocNav and using Vivado 2017.3. I have no trouble until I attempt to run the behavioral simulation. At that point I get the error code:
[VRFC 10-664] expression has 20 elements ; expected 24 ["File Path/Vivado Tutorial Files/ug937-design-files/sources/sinegen.vhd":52]
Upon opening the file everything looks as it should, and there should be no expectation of 24 elements according to the Logic Simulation Tutorial parameters.
prathikm
Hi @jvogesnw,
Please check this thread to see if it useful.
This happens when there is a mismatch in declaration.
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
prathikm
Hi @jvogesnw,
jvogesnw
@prathikm,
Thanks for your reply, I had multiple mismatched values that all needed a different declaration value. This was all generated by Vivado, should it be reported as a bug?
prathikm
Hi @jvogesnw,
Thanks for the update. Which lab/step were you working on in this tutorial?
Will be interesting to try this at our end once.
jvogesnw
I was on Step 3, the 5th instruction. Everything was done according to the tutorial, and I performed it with the KC105 and then the KCU705. Both had the same issue.
prathikm
Okay. Let me check running those at our end once.
I will update this thread.
Best Regards,
Prathik
sunilku
Hi @jvogesnw
I didn't see any issues while running Logic Simulation Tutorial on Linux redhat machine using 2017.3. I have tried both the boards that you have mentioned in the thread.
Can you please try once again following the steps in Tutorial.
Sunilkumar
jvogesnw
@sunilku,
I performed the tutorial five times on Windows 10 2017.3 and had the same errors each time. If I edit the file then the simulation runs correctly each time. Thanks for trying it on Linux Redhat, perhaps this is an issue with my individual download, or the windows installer.
Jacob
