rtt42
Unexepted EOF : missing `endif
I am converting an ASIC design that has been verified in simulation, to a Vivado project.
On input the syntax checker is reporting 10 instances of:
[HDL 9-850] Unexpected EOF : missing `endif <filename.v>
We have checked all the files and every `ifdef / `ifndef / `elsif has a corresponding `endif  as already verified by the other simulator
Any suggestions on what to look for next?
rtt42
We have resolved the issue.
The problem is NOT a dangling `ifdef, `endif or the like.  Rather it was a dangling "// synopsys  translate_off" which, of course, our ASIC simulator ignored.  As there was no coresponding "// synopsys  translate_on" the whole code base was messed up.  That it only affected 10 files out of about 40 or so is remarkable!
Thank you evryone for your help.  It did eventually lead to a resolution
austin
Check for a carriage return, line feed at the end,
I have seen some editors/tools reject .v files without a blank line at the end.
I usually see this when I use someone elses files for ptotoyping an ASIC in an FPGA (they used completely different tools).
Austin Lesea
Principal Engineer
Xilinx San Jose
rtt42
Hmmm.   Checked the 10 files that Vivado complains about and added a few extra lines on the end
Same result!
Checked all the files in the design and did the same to them all
Same result!
Same 10 files everytime that have the error.  Some of them have no `ifdef/`endif statements at all
Any more ideas
bwiec
I usually see this when I forget the 'endmodule' at the end.
www.xilinx.com
rtt42
Nope I have all of them!
Besides it wouldn't simulate in the ASIC environment without the correct number of 'endmodules'
arpansur
Hi @rtt42,
Can you please attach the code here in which you are getting warning?
Is "begin" is ended with "end"?
Arpan
Arpan
tusharvi
Hi @rtt42
Can you post any one of these files (or a test snippet) which can reproduce this issue?
Tushar
nupurs
Hi @rtt42 ,
Can you try by inserting a semicolon at the end of files?
Nupur
Nupur
rtt42
