mhmontazeri61
Unknown non-related timing simulation error
During Simulation of a simple code with a process for handling bram addresses and data and a block ram, behavioral simulation was ok and post implementation timing simulation failed due to the following errors(in vivado 2017.1 tool):
Vivado Simulator 2017.1
Copyright 1986-1999, 2001-2016 Xilinx, Inc. All Rights Reserved.
Running: C:/Xilinx/Vivado/2017.1/bin/unwrapped/win64.o/xelab.exe -wto 05e12adfc7be44e8acfa1817272fc792 --debug typical --relax --mt 2 --maxdelay -L work -L simprims_ver -L secureip --snapshot TB_uut_time_impl -transport_int_delays -pulse_r 0 -pulse_int_r 0 -pulse_e 0 -pulse_int_e 0 work.TB_uut work.glbl -log elaborate.log
Using 2 slave threads.
Starting static elaboration
ERROR: [VRFC 10-380] binding entity \uut\ does not have generic gdest
[C:/Users/sim/sim.srcs/sim_1/imports/Desktop/TB_uut.vhd:43]
ERROR: [VRFC 10-380] binding entity \uut\ does not have generic gsrc
[C:/Users/sim/sim.srcs/sim_1/imports/Desktop/TB_uut.vhd:44]
ERROR: [VRFC 10-380] binding entity \uut\ does not have generic gupd
[C:/Users/sim/sim.srcs/sim_1/imports/Desktop/TB_uut.vhd:45]
ERROR: [VRFC 10-380] binding entity \uut\ does not have generic gups
[C:/Users/sim/sim.srcs/sim_1/imports/Desktop/TB_uut.vhd:46]
ERROR: [VRFC 10-380] binding entity \uut\ does not have generic gudd
[C:/Users/sim/sim.srcs/sim_1/imports/Desktop/TB_uut.vhd:47]
ERROR: [VRFC 10-380] binding entity \uut\ does not have generic guds
[C:/Users/sim/sim.srcs/sim_1/imports/Desktop/TB_uut.vhd:48]
ERROR: [XSIM 43-3322] Static elaboration of top level Verilog design unit(s) in library work failed.
What is the problem?
mhmontazeri61
mhmontazeri61
All Xilinx tools have problem with testbenches include component instantiation with default component generic mapped in testbench. Very confusing...
Re
mhmontazeri61
thakurr
Hi @mhmontazeri61
With the test case attached i am not able to reproduce the issue in 2017.1 as well as 2017.2. Post implementation timing simulation matches behavioral simulation and there are no such erros or warnings. Can you please check this if you are doing anything wrong or correct me if i am wrong?
Share your code to reproduce the issue.
Rohit
Rohit
bandi
Hi @mhmontazeri61,
Can you please check these related posts and see if it helps:
https://forums.xilinx.com/t5/Simulation-and-Verification/binding-entity-does-not-have-generic/td-p/670537
https://forums.xilinx.com/t5/Simulation-and-Verification/Post-synthesis-simulation-error-VRFC-10-380-generics-issue/td-p/701966
If this doesnt help then can you please share your design to check at our end. Also, can you please let us know if you come across the same error while running post synthesis simulation ?
Sravanthi B
Thanks & Regards,
Sravanthi B
mhmontazeri61
@thakurr,
your attached design was successful im my PC and my tool too. I can not understand the difference between these two designs. Please send me your private mail for sending codes if it's possible for you.
Re
mhmontazeri61
thakurr
Hi @mhmontazeri61
I have sent you the package through Ezmove link. Please upload your project there.
Rohit
Rohit
