Unresolved reference to 'gen_rd_a' in gen_rd_a.douta_reg
I am getting the above warning during Questa Sim Elobration of simulating a Spartan 7 for xpm_memory.sv file.   Any help on what is causing this and how to fix it?
Regards-
Mike
Re: Unresolved reference to 'gen_rd_a' in gen_rd_a.douta_reg
Hi @mjhorwath,
Have you compiled the simulation libraries successfully for Questasim? Which version of Questasim are you using and with which vivado?
Can you please share the compile_simlib.log and the transcript file to check.
Thanks & Regards,
Sravanthi B
I've had this problem too.  I resolved it by turning off optimization (vopt) in the modelsim.ini file.
VoptFlow = 0
This does make your simulation run slower.  Fair warning.
Bob
