Use AXI BFM Verilog API Taks with SystemVerilog
i want to simulate my axi-ip by using systemverilog and the axi bfm. Can i use the verilog api from the axi bfm within systemverilog. Thank you.
Re: Use AXI BFM Verilog API Taks with SystemVerilog
Sure, it should work fine. SV is a superset of verilog. So verilog constructs also work fine in SV (but not all systemverilog constructs work in standard verilog)
www.xilinx.com
