Using Aurora 64B66B with third party simulator
I'm relatively new to Aurora and how it works but I need to use it in part of a test bench for another in house IP to test if it works. How can I go about compiling and elaborating the Aurora files outside of Vivado (using VCS L-2016.06-SP2) with my own files included? I've been able to run it fine by itself within Vivado using VCS but I can't work out how to get it simulating with my own files included.
I have managed to get it to work under Questa. You have to run under Tools>Create and Package New IP to package the aurora_64b66b IP. This will create simulation scripts that you can borrow from to create the scripts for your project. After running the packager look under vivado/project_name/project_name.ip_user_files/sim_scripts/aurora_64b66b_xxxx/simulator_of_your_choice.
Paste into your scripts the lines from the appropriate script files changing the root paths as required.
Regards, Ray Haynes, Ostendo Technologies, Inc. Carlsbad, CA
Thanks! Didn't know this was an option to do within vivado
