rikusleroux
Using UNISIM components in Questa
Hi guys,
I'm having some issues with Questa Sim. I'm trying to simulate a design with BUFG and DCM components. The following library declarations exist in my top level design as well as in my testbench:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_unsigned.all ;
use IEEE.std_logic_textio.all;
use std.textio.all ;
library UNISIM;
use UNISIM.all;
use UNISIM.vcomponents.all;
However, I get the following errors when synthesizing in Questa:
"Identifier "BUFG" is not directly visible." and "Identifier "DCM_BASE" is not directly visible."
The UNISIM library is available and compiled in Questa (I see it under the libraries-tab). Why are these components not directly visible? I have an ICAP instantiates as well and this seem to simulate correctly. What am I doing wrong?
graces
Try removing "use UNISIM.all".
graces
rikusleroux
Hi graces, Thanks a lot! That worked like a charm. Why did that cause a problem? Are the component-libraries included multiple times by UNISIM.all and UNISIM.vcomponents? Why can't I just include UNISIM.all since vcomponents are inluded by "alll"?
