VCS compile_simlib vivado 2018.3 lib failed
vcs version :O-2018.09-SP2\N-2017.12-SP1
error info:
Why i use new version vcs cann't compile old vivado ?must comply with version  match  strictly?
回复: VCS compile_simlib vivado 2018.3 lib failed
While we do recommend the exact compatible version as that is tested, I don't think the key point here is the version. The warning prior to the error may need your attention.
Warning- [MXIR-W] VCS-MX build is required
Please make sure that vlogan is from the intended build.
Did you run VCS or VCS-MX?
