VHDL 2008 generic packages
In the attached zip folder are present the following files:
            -in control_interface_lib is present a generic package and a file that instantiate it,
            -in mpp_ip_lib is present a package used by the previous files.
This code is correctly compiled by Vivado 2017.1, giving me no error. On the contrary using the compile of questa 2019_2 I have some errors. Writing to the support they said that my error is due to the fact that in the generic package I call the function to give values to constants before that they are elaborated and that is strange that this code is ok for Viavdo. So I'm wondering if the code is really wrong and if yes why Vivado is compiling correctly the code if it is wrong? Maybe it is not preforming some checks that instead are made by questa simulator?
Thanks in advance for the answer.
Scholar richardhead
Re: VHDL 2008 generic packages
Not sure how you got it working in 2017.1, as it is confirmed as not working in 2017.2, and Vivado has pretty poor 2008  support:
https://forums.xilinx.com/t5/Synthesis/How-to-use-generic-packages-as-introduced-in-VHDL-2008/m-p/705147
Only 2019.1 officially supports generic packages:
https://forums.xilinx.com/t5/Synthesis/Availablility-of-UG901-Synthesis-Guide-for-2019-1/m-p/978781
But modelsim is correct. You will need to defer the constants because they are in a package:
package some_package is
  constant DEFFERED_CONSTANT : integer;
end package;
package body some_package is
  function some_function return integer is
  --blah blah
  constant DEFFERED_CONSTANT : integer := some_function;
end package body;
Scholar richardhead
end package;
  --blah blah
end package body;
