VHDL package not comiled in work library -> Vivado 2013.3 Simulator
have the following package with some record declarations:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
package interface_pack is
    type data_set_32bit is record
        data :std_logic_vector(31 downto 0);
        valid :std_logic;
        eol :std_logic;
        eof :std_logic;
        toggle: std_logic;
    end record;
    type data_set_16bit is record
        data :std_logic_vector(15 downto 0);
        valid :std_logic;
        eol :std_logic;
        eof :std_logic;
        toggle: std_logic;
    end record;
    type data_set_12bit is record
        data :std_logic_vector(11 downto 0);
        valid :std_logic;
        eol :std_logic;
        eof :std_logic;
        toggle: std_logic;
    end record;
    type data_set_32bit_complex is record
        data :std_logic_vector(63 downto 0);
        valid :std_logic;
        eol :std_logic;
        eof :std_logic;
        toggle: std_logic;
    end record;
end interface_pack;
In my Design file i use the package with "use work.interface_pack.all;" but when i will simulate it i get the following error:
ERROR:  [VRFC 10-149] 'interface_pack' is not compiled in library work...
I don't understand this, because in the Vivado Sources view (Libraries Tab) the package exists in work -> see screenshot.
Has anyone an idea?
Thank's
Re: VHDL package not comiled in work library -> Vivado 2013.3 Simulator
Try change the design to not use the package, meaning remove the "use" reference to the utils package and add component declarations.
Thanks,Vijay
Please check the .prj file located in <project>.sim/sim_1directory. It looks the package file is not included in the compile list.
If this is the case, try setting the package file as global include file.
Select the package files and check "IS_GLOBAL_INCLUDE" in the Properties tab in the Source File Properties window.
If it still doesn't work, you'll have to create a custom .prj with the complete file list and launch simulation from command line (the xelab command can be referenced from .log file located in sim_1 directory).
I had the same problem.  I can confirm that checking "IS_GLOBAL_INCLUDE" fixed the issue in Vivado 2013.2.
Thanks!
@voco-mannheim Is the issue fixed at your end? Do you have any further questions on this thread?
Debraj
I have a similar problem, in general, with VHDL files that are instantiated like this:
u_xyz : entity work.abc
instead of:
component abc
end component
u_xyz : abc
If I run simulation I get the message: "[VRFC 10-149] 'abc' is not compiled in library work". However, I if I use the 2nd method, at least once, then switch back to the 1st method, it works. So I think the problem is that Vivado is not (re)compiling the modules into library work, unless the module is specifically declared as a component, in the same file where it is used. The first example is perfectly valid VHDL and should be supported.
Is there a way to 'force' Vivado to just recompile a module, into its library (work)? I haven't found one. I think this has caused problems in other situations as well.
Dan
@debrajr, This is still a problem in 2014.4. Any idea if it is on the list to be fixed in 2015.1?
The global include is not as bad a workaround as I initially thought. you only need to make it global for a single run, than you can unclick the global and it will continue to work.
Ist there any news on this matter? It seems still to be an issue with 2016.2.
I cannot compile VHDL sources which compiled fine in ISE: I need to add work.MyEntity before every entity I'm using and specify the "global include" for all the files, then it compiles.
It is a possible workaround, but it is a lot of work and I need to alter all the sources (to add the "work." prefixes).
Has anyone found a better way?
Stefan
instead of
use package_name.all
try this:
use work.package_name.all
I have the same problem while I am trying to simulation a child module in project.
and solved it by enabling IS_GLOBAL_INCLUDE in Source File Properties.
Solved for me by just making the compile order correct - i.e. put packages first in the compile order
