drjohnsmith
VHDL variables in simulation
What is the current status of the Xilinx simulators to show VHDL variables in the trace window ?
Im on a tablet right now, so cant try, but I seem to rember we needed to use other simulators like Modelsim to be able to view vhdl variables,
I had look in forums, but we have all sorts of 'answers' , yes / no / may be.
any one have a thought please ?
In Vivado v2018.3 during Functional Simulation, when I do the following:
1) Select "Check All Filters" in the Scope window settings
2) Select "Variable" in the in the Objects window settings
then the Objects window shows VHDL variables and their values - from both the testbench and the design-under-test.  However, the "Add to Wave Window" option for the VHDL variable is greyed-out.
So, I think answer is no.
