Visitor spl1nk
VIVADO 2018.2.1 ERROR: [USF-XSIM-11] Failed to open file to append
Hello everyone,
I am currently trying to simulate a project, got the testbench set up, etc. However, when i try to simulate, I get the folowing error message:
"[USF-XSIM-11] Failed to open file to append (/$project_dir$/.sim/sim_1/behav/xsim/xsim.ini)"
I have not found anything that might hint at the problem or how to fix this. The design is a regular vhdl design, the only exception is the inclusion of a fifo_generator ip_core.
Does anybody know where this comes from, or how to resolve this?
Thank you in advance,
spl1nk
Visitor spl1nk
Re: VIVADO 2018.2.1 ERROR: [USF-XSIM-11] Failed to open file to append
I fixed the error myself.
For an unknown reason, 'Vivado/2018.2/data/xsim/xsim.ini' was write-protected, and when copied by Vivado into the project folder, this write-protection was kept. Removing the write-protection from the original error resolved the problem.
Hi @spl1nk,
Can you please try resetting simulation, then run the simulation again and see if it helps.
Visitor spl1nk
hey @shameera,
i tried to use the 'reset_simulation' command, right clicking and selecting 'Reset Behavioral simulation', as well as 'file delete -force xsim.ini', but to no effect. I also created a completely new project, with the same source files, and generated a new fifo_generator, but nothing happened. This is the output when I try to run the simulation again:
launch_simulation
INFO: [Vivado 12-5698] Checking validity of IPs in the design for the 'XSim' simulator...
INFO: [Vivado 12-5682] Launching behavioral simulation in '/home/debus/projects/PETA6_Readout/PETA6_Readout_Test/PETA6_Readout.sim/sim_1/behav/xsim'
INFO: [Vivado 12-4795] Using compiled simulation libraries for IPs
INFO: [SIM-utils-51] Simulation object is 'sim_1'
INFO: [USF-XSim-7] Finding pre-compiled libraries...
INFO: [USF-XSim-11] File '/opt/ISEfull/Vivado/2018.2/data/xsim/xsim.ini' copied to run dir:'/home/debus/projects/PETA6_Readout/PETA6_Readout_Test/PETA6_Readout.sim/sim_1/behav/xsim'
ERROR: [USF-XSim-11] Failed to open file to append (/home/debus/projects/PETA6_Readout/PETA6_Readout_Test/PETA6_Readout.sim/sim_1/behav/xsim/xsim.ini)
ERROR: [Common 17-39] 'send_msg_id' failed due to earlier errors.
    while executing
"send_msg_id USF-XSim-011 ERROR "Failed to open file to append ($file)\n""
    (procedure "usf_set_compiled_lib_dir" line 28)
    invoked from within
    (procedure "usf_xsim_setup_simulation" line 43)
    invoked from within
    (procedure "tclapp::xilinx::xsim::setup" line 19)
    invoked from within
"tclapp::xilinx::xsim::setup { -simset sim_1 -mode behavioral -run_dir /home/debus/projects/PETA6_Readout/PETA6_Readout_Test/PETA6_Readout.sim/sim_1/be..."
ERROR: [Vivado 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
ERROR: [Common 17-39] 'launch_simulation' failed due to earlier errors.
Visitor spl1nk
I think i have made a little progress. "INFO: [USF-XSim-11] File '/opt/ISEfull/Vivado/2018.2/data/xsim/xsim.ini' copied to run dir:" seems to indicate that the xsim.ini file is always copied over from the installation directory. However, looking at it in my project folder, it seems to be write-protected. Removing the write-protection from the file in the project folder does not help, as it is always written over with the write-protected file from the installation-directory. I do not know exactly why this is write-protected, but maybe removing that would help. Is this advisable, or would i break something if i try this?
Also, I managed to find a workaround. By removing the fifo-generator IP from the project, and instead using the simulation netlist as a file directly, seems to have removed the need for the xsim.ini file. With this, i can start the simulation as is.
Visitor spl1nk
