VIVADO batch simulation problems
I'm using VIVADO 2014.4, 64 bits, VHDL
I'm trying to use simulation in batch mode with makefiles.
It is new for me, but I have to as it is requested by the final user !!
1)  How to configure my testbench file from makefile ?
I want to configure my testbench file using VHDL generic.
I have the following VHDL :
entity tb_test is
  generic
    -- System Configuration
    constant N_CONFIG                  : integer := 2    );
end entity tb_test;
architecture sim of tb_test is
I tried the following command
xelab -initfile ../xxx/xsim.ini -debug typical tb_test -s xsim_tb_test -generic_top "N_CONFIG= 2"
but I get :
Running: C:/Xilinx/Vivado/2014.4/bin/unwrapped/win64.o/xelab.exe -initfile ../xxx/xsim.ini -debug typical tb_test -s xsim_tb_test -generic_top N_CONFIG= 2
Multi-threading is on. Using 2 slave threads.
Starting static elaboration
ERROR: [VRFC 10-1509] unknown actual generic literal value 2 for generic n_config ignored
I also tried
xelab -initfile ../xxx/xsim.ini -debug typical tb_test -s xsim_tb_test -generic_top "N_CONFIG=2"
But I get
Running: C:/Xilinx/Vivado/2014.4/bin/unwrapped/win64.o/xelab.exe -initfile ../xxx/xsim.ini -debug typical tb_test -s xsim_tb_test -generic_top N_CONFIG 2
ERROR: [XSIM 43-3225] Cannot find design unit work.2 in library work located at xsim.dir/work.
I just can understand what is wrong !
I'm wondering if it usable with VHDL ?
Any one has a clue ?
2) How to initialize Microblaze memory file with elf ?
In the GUI mode, I assign .elf files for implementation and simulation and it works fine.
Here in batch mode, I just dont see where and how to do it !
Thank you !
Stephane.
