forgodbok
VIVADO "Open IP Example Design" template
I wanted to simulate some IP core.
Since I'm used to using verilog, I created project with verilog option
Then I generated IP core which I want. I clicked "Open IP example design" by righ-click of IP core.
VIVADO generated example simulation....but it was VHDL.
Is there any initial setting for verilog template?
Thank you!
prathikm
Hi @forgodbok,
You can refer the respective IP Product Guide to see if Verilog example design is provided for the core or not. This will be usually in the core specs table section. As an example below.
Go to this link (link1) then search the IP name > Click on IP name > Documentation > Select the guide to refer.
Prathik
Don't forget to reply, kudo, and mark the appropriate post as 'accept as solution'.
prathikm
Hi @forgodbok,
Prathik
forgodbok
Thank you
you are correct...it was specified in product guide.
