jmcm
VRFC 10-900
I have a very small design that fails simulation.
The design consists of 1 AXI VIP configured as an AXI-Lite master and 1 GPIO configured as 1-bit output only.
All that the test-bench does is output a 0 in the GPIO,  then a 1, then a 0.
I get the following error message:
VRFC 10-900 "Incompatible complex type assignment" at this line in the test-bench:
mst_agent = new("master vip agent", DUT.axi_vip_0.inst.IF);
I found one post in the Xilinx forum that talks about this.  The solution was to change the simulation language to Verilog.  I made sure that I have Verilog selected but I still get the same error.
Do  you have any suggestions what I am doing wrong?
Jacques
graces
What is the Vivado version that you're running?
Are you able to run simulation for the AXI VIP example design?
graces
jmcm
I didn't try this one.  But I am able to run simulation in the v_tpg_o_ex example design which also contains a AXI VIP.
When I run the post_synthesis functional simulation I get a different message:
VRFC 10-93: IF is not declared under prefix inst
In the sources hierarchy of the example design I see:
ex_sim_axi_vip_0_0
  inst : axi_vip_v1_1_3_top
    ? IF : xil_defaultlib.axi_vip_if
In my design I don't have the IF under inst.
So this could be the problem.  How can I fix this?
Jacques
jmcm
I found the problem.
In the AXI_VIP customization window, Advanced Settings, field HAS RRESP must be 0.
Now the simulation runs.  But I still don't have IF under inst in the sources hierarchy.
Jacques
jmcm
Setting the HAS RRESP parameter to 1 makes the simulation runs in behavioral mode but not in post-systhesis mode.  I am still getting the VRFC 10-93 error message.
So I need a way to add the IF interface in the axi_vip hierarchy under inst.
Could you please provide a way to do this?
Jacques
jmcm
I meant setting the HAS RRESP parameter to 0 in my previous post.
Sorry about that.
Fictivelogic
RRESP to 0 was the solution. Thank you @jmcm  !!!
