Verilog Compxlib Naming Issue
Whenever I use compxlib to generate the simulation libraries for modelism I can't use the verilog verision (ex unisims_ver) to simulate because modelsim thinks the files don't exist. It believes this because the files all have @ symbols stuck in the path names (see attached). Is this normal behavior, and if not how can it be rectified?
Hello @jmayer16
Which version of ISE and modelsim are you using?
Vinay
Hi @jmayer16
What is the exact error you are seeing and what is your machine language settings?
Thanks,Vijay
Hi @vuppala,
I'm using Vivado 2014.2 and Modelsim-SE 10.1c.
Hi @jmayer16,
You are not using supported third-party simulator. Vivado 2014.2 can be used with QuestaSIM SE 10.2a. Please check the following link at page 10:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug973-vivado-release-notes-install-license.pdf
So, please try to use one of the supported simulators.
Nupur
Nupur
