Verilog Literals
Hi @dgisselq ,
Could you pls, illustrate these two literals (Blue-Cirlced) :literals.JPG
What is dead_beaf !?
What is 100_000_000 ?
Note : this picture from lsn_01
Scholar dgisselq
Re: Verilog Literals
@ahmed_alfadhel,
Let's step through those.  First, ,both example literals begin with a 32'.  This means they each have 32-bits to them.  One literal is then followed by an `h` indicating a hexadecimal number, while the other is followed by a `d` indicating a decimal number.  Further, Verilog allows underscores within numbers as separators and the parser just ignores them.  Hence, the two numbers might also be written as 0xdeadbeef or 100000000 in a more traditional software context.  Notice how these are harder to read--the 100,000,000 value in particular, because there are so many zeros in it.  The underscores really helped to make it legible, although they didn't adjust its value at all.
Dan
Scholar dgisselq
@ahmed_alfadhel,
Dan
@dgisselq
What about the deadbeaf?
could it stands for sth before define it?
Scholar dgisselq
Did you notice that all of the characters in 32'hdead_beef where between a and f?  These are valid hexadecimal characters.  This is a fun number to use since it can also be "read", but it is still a number.  Mapping it to decimal, I get 3,735,928,559.
Note that this is a literal, not a variable.  It begins with a # (i.e. 32).  Variables cannot begin with numbers.  Therefore it doesn't need to be "defined", but rather is a value in its own right.
Dan
@dgisselq  ,
I am impressed by you.
Great Thanks for you.
