tessitd
Verilog Simulation using DPI standard C math functions
All,
I just created a new install of Vivado on a CentOS 7 machine. I am getting a simulation fatal for my design in that the simulator cannot find the standard C-math functions I have linked via the DPI.  What CentOS 7 packages do I need to have loaded to make this work?  I have glibc and glibc-devel which is what I thought would do it but it isn't.
I have run this on both a Windows and a CentOS 6 machine so I know the Verilog code is correct, this is something new to this installation on CentOS 7.
The Vivado version is 2017.4.
TomT...
amaccre
Hi @tessitd,
The following Answer Record, provides a method to isolate which packages are missing with a link to a script that will analyse and list the packages.
AR# 66184 Install - How do I find out which libraries are required to run Vivado tools in Linux?
https://www.xilinx.com/support/answers/66184.html
This should be a good place to start.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
