Virtex 6 FPGA programming on windows 10
How to program Virtex 6 series FPGAs in Windows 10 platform as there is no official support from Xilinx?
Thanks in Advance!
Re: Virtex 6 FPGA programming on windows 10
If it's just loading code, Vivado can do that (even for the old chips).
If you need to write code for the Virtex 6, you can either use ISE 14.7 (may or may not work properly) or you can run a virtual machine with a supported OS and run ISE 14.7 on that instead.
