[Vivado 12-5602] compile_simlib failed to compile for ies in 183 libraries
I met below error when compile the sim lib for ies in Vivado.
ERROR: [Vivado 12-5602] compile_simlib failed to compile for ies with error in 183 libraries (cxl_error.log)
Can some one help on this?
Thank you.
Re: [Vivado 12-5602] compile_simlib failed to compile for ies in 183 libraries
Hi @tiandabinbin ,
Can you share the error.log file.
Also please share the Vivado Version and IES version you are working with.
Raj
Hi Raj
Below are the tool version I used.
Vivado v2018.2 (64-bit)
cadence-incisiv-  15.20.042
Log file is attached.
It seems that vivado is calling the ncvhdl_p  to compile the VHDL libraries, but ncvhdl_p is not available in my env.  There is only ncvhdl and ncverilog in my env.
May I have your suggestions on this?
Thank you.
Hi @tiandabinbin,
Looks like environment variables issue. Please open a new terminal and set the below environment variables if you are using a csh shell. Please use export command if you are using a bash shell
setenv CDS_INST_DIR <IES_15.20.042_install_path>
setenv PATH $CDS_INST_DIR/tools/bin:$PATH
setenv LD_LIBRARY_PATH $CDS_INST_DIR/tools/lib:$LD_LIBRARY_PATH
Please make sure that you invoke vivado from the same terminal in which you have set the above environment variables and then try to compile simulation libraries.
Hi Shameera
Thanks for your suggestion.
With below env. variable settings, most of the comile errors can be solved, except for below 2 errors.
Fortunately, we will not use below two libraries for now. But it will be nice that you can help on below two errors.
* processing_system7_vip_v1_0_3 | verilog | processing_system7_vip_v1_0_3 | 1 | 0 *
* zynq_ultra_ps_e_vip_v1_0_1 | verilog | zynq_ultra_ps_e_vip_v1_0_1 | 1 | 0 *
ERROR: [Vivado 12-5602] compile_simlib failed to compile for ies with error in 2 libraries (cxl_error.log)
Thank you.
Hi @tiandabinbin ,
Can you please share the compile_simlib.log file generated while compiling simulation libraries ?
