tomkulaga
Vivado 2014.3
Will the upcoming vivado support vhdl 2008?
yenigal
No,it is planned for 2015.x
What are the constructs you are using or looking for, as this data will be helpful for us for the initial beta release.
Satish
yenigal
Yes,VHDL 2008 in beta support for RTL synthesis will be released with version 2014.3 of Vivado
Satish
tomkulaga
Awesome thanks.
Is simulation also planned?
yenigal
Satish
tomkulaga
Thanks for you reply.
I was after having a go with http://osvvm.org/ which requires protected types (vhdl 2002).
Is there a list of VHDL200x features that are available in the upcoming release?
yenigal
The supported features will be made public with 2014.3 release.
Satish
tomkulaga
Is that for sim or synthesis?
yenigal
That is for synthesis and offcourse you have to wait till 2015.x for the simulation features as these features are not finalised and the initial features will depend on the most used/requested data from customers.
Satish
tomkulaga
Thanks for the info.
