Newbie griffinj
Vivado 2014.4 Simulator Error XSIM 43-3225
I'm getting a library error in the elaboration step of my simulation.  Vivado "Cannot find design unit xil_defaultlib.Viterbi_CPA_v2_tb in library work located at xsim.dir/work."  I've checked to ensure the library for every file in the project is set to xil_defaultlib.  Per AR# 56685 at https://www.xilinx.com/support/answers/56685.html, I checked for directory <project_name>.sim/sim_1/synth/func/.  This directory does not exist in my project working tree, and I don't know how to move forward with the error.
Thanks!
Joe
Re: Vivado 2014.4 Simulator Error XSIM 43-3225
Hi @griffinj
Can you please try creating the project from scratch and see if that helps?
Also try using the latest version of Vivado for better results.
Thanks,Vijay
Hi @griffinj
Thanks,Vijay
Newbie griffinj
My Vivado version is fixed because the code my group is working with has been developed over several Vivado iterations. Generating the project from scratch solved the problem.
