[Vivado 2014.4] ncelab: *W,REALCV: Real argument converted to integer for (%d) in MMCME2_ADV.v
With Vivado 2014.4 two new warnings are showing up with ncelab:
 $display(" Input Error : %s CLKFBOUT_MULT_F has been programmed through DRP to %f which is over the range of %d to %d. Instance %m at time %t.", MODULE_NAME, clkfbout_f_div, M_MIN, M_MAX, $time);
ncelab: *W,REALCV (/opt/cad/xilinx/Vivado/2014.4/data/verilog/src/unisims/MMCME2_ADV.v,2550|186): Real argument converted to integer for (%d).
ncelab: *W,REALCV (/opt/cad/xilinx/Vivado/2014.4/data/verilog/src/unisims/MMCME2_ADV.v,2550|193): Real argument converted to integer for (%d).
Tested with Cadence IES 13.10-s022. Replacing %d with %f resolves the issue. Even though it is only a warning, it hopefully can be fixed with next release.
Re: [Vivado 2014.4] ncelab: *W,REALCV: Real argument converted to integer for (%d) in MMCME2_ADV.v
these warnings are shown because value after decimal is terminited for %d. when you replace it with %f it will show you values after decimal point. so according to me tool is doing the correct job.
thanks,
Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in left) to a post which you think is helpful and reply oriented.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
As I already said, replacing %d with %f does solve this. And sure ncelab does correct job. However, the MMCME2_ADV behavioral model is part of the Vivado release and I don't want to fix this in every future release on my side.
Hi @tud_hartmann ,
Can you please post the testcase? I will check in the latest internal build and update you.
Thanks,Vijay
Hi @vijayak,
please find attached small testcase to reproduce the problem. Adjust the settings at the beginning of the run script to match with your environment.
Thanks and best regards, Stephan
I see the same warning with the latest build. I will get back to you on this.
Thanks,Vijay
