Vivado 2015.1 ModelSim PE (evaluation) support
Can a ModelSim PE evaluation license be used with Vivado 2015.1?  I get an error when I try to simulate:
Load of "C:/Xilinx/Vivado/2015.1/lib/win64.o/libxil_vsim.dll" failed: Bad DLL format.
According to this AR: http://www.xilinx.com/support/answers/62210.html, the error is occuring because ModelSim PE is 32-bit and Vivado is 64-bit, so the libraries aren't compatible.  However, there is no longer an option to run Vivado with the -m32 switch as the AR states, so it appears the two are currently incompatible.  Any way to work around this issue?
I have the same problem with Riviera-PRO LV.
I can see path "C:\Xilinx\Vivado\2015.1\lib\win32.o" in my Vivado 2015.1 install directory.
There's no "win32.o" in C:\Xilinx\Vivado\2015.1\bin\unwrapped though.
The library path points to 64-bit one. What if you manually modify the generated script to point to win32.o and run the script standalone in Modelsim?
The win32.o folder does not exist on my machine, because as far as I can tell, Vivado 2015.1 is only 64-bit.  Is there a way for me to install the necessary 32 bit components?
I must have missed that path when I was looking before.  After modifying the simulate.do script to point to the 32-bit library, I'm able to run simulations.  Thank you!
