Vivado 2015.3 XSIM testplusarg
If I run the following command with batch file(simulate.bat) , completes with error.
But I run the command in Xsim(TCL Script), completes with no error.
In batch file case, Xsim does not recognize the option "-testplusarg".
The other is ok.
====  Command ======
xsim board_behav -key {Behavioral:sim_1:Functional:board} -gui -wdb board_behav.wdb -view board_behav.wcfg -log simulate.log -testplusarg TESTNAME=BMD_Rd_DMA
@linuxbios
Use the option as -testplusarg "TESTNAME=BMD_Rd_DMA" in your testcase. That should work.
Debraj
Hi @linuxbios,
If you are using windows, make sure you call the xsim executable:
Refer to this AR for details: http://www.xilinx.com/support/answers/63986.html
Let me know if this helps.
Nupur
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
Are you seeing an error as -testplusarg is not defined or the error is that the testplusarg are not applied to your verilog code?
Also, in simulate.bat, you would see the entry as:
set xv_path=C:\\Xilinx\\Vivado\\2015.2\\bin
call %xv_path%/xsim Testbench_behav -key {Behavioral:sim_1:Functional:Testbench} -tclbatch Testbench.tcl -log simulate.log
Are you running the same command in TCL also?
Debraj
I attached the result after running "simulate.bat"
=== Command =====
Hi @linuxbios
I tested plusargs at my end with a simple code:
module valuetest();
integer i;
initial
begin
if($value$plusargs("INTG=%d",i))
$display(" GOT INTEGER ");
$display(" Integer is %d ",i);
end
endmodule
And in xsim used: -testplusarg INTG=123
Output:
GOT INTEGER
Integer is 123
Can you please cross check your usage?
Thanks,Vijay
I attached the file what I did as you said.
I failed with the same error.
Hi @linuxbios
Iam attaching the scripts with which Iam able to run the design for your reference.
Thanks,Vijay
Use it as -testplusarg "TESTNAME=BMD_Rd_DMA" in Command Prompt of Windows and not -testplusarg TESTNAME=BMD_Rd_DMA. The " " are missing for the argument list.
Debraj
I tested your zip file.
The result is fail with the same error.
@linuxbios
Debraj
Thanks your reply.
"tcl script" works either ways.
"batch file" works only one way("TESTNAME=BMD_Rd_DMA").
That are my result.
But, Any user guides do not use of ("TESTNAME=BMD_Rd_DMA") way.
