gabich
Vivado 2017.2 compile_simlib error
I was trying to compile the unisim lib to ModelSim soi have got some errors.
Vivado% compile_simlib -library unisim -simulator modelsim -directory {/soft64/altera/17.0/modelsim_ase} -verbose -force
INFO: [Vivado 12-4753] Extracting data from the IP repository...(this may take a while, please wait)...
INFO: [setup_ip_static_library-Tcl-23] Data extracted from repository. Inspected 356 IP libraries.
Library Source Paths => '/soft64/xilinx/Vivado/2017.2/data /soft64/xilinx/Vivado/2017.2/ids_lite/ISE'
Current Working Directory => '/home/gabich'
Compilation Mode = FAST
Compilation Format = 64-bit
Execute Mode = ON
Execute Platform = lin64
Scheduling library installation & compilation for architectures: all
Scheduling library installation & compilation for libraries: unisim xpm
Signature:-
compile_simlib -library unisim -simulator modelsim -directory /soft64/altera/17.0/modelsim_ase -verbose -force
Executing cmd '/soft64/altera/17.0/modelsim_ase/linuxaloem/vcom -version -64' with output '.cxl.modelsim.version' (Wed Jul 26 19:01:34 2017)...
compile_simlib[exe]: The command line '/soft64/altera/17.0/modelsim_ase/linuxaloem/vcom -version -64' returned exit code '7'.
Compiling libraries for 'modelsim' simulator in '/soft64/altera/17.0/modelsim_ase'
Executing cmd '/soft64/altera/17.0/modelsim_ase/linuxaloem/vlib /soft64/altera/17.0/modelsim_ase/secureip' (Wed Jul 26 19:01:34 2017)...
compile_simlib[exe]: The command line '/soft64/altera/17.0/modelsim_ase/linuxaloem/vlib /soft64/altera/17.0/modelsim_ase/secureip' returned exit code '0'.
Executing cmd '/soft64/altera/17.0/modelsim_ase/linuxaloem/vmap secureip /soft64/altera/17.0/modelsim_ase/secureip' with output '/soft64/altera/17.0/modelsim_ase/secureip/.cxl.verilog.secureip.secureip.lin64.log' (Wed Jul 26 19:01:34 2017)...
compile_simlib[exe]: The command line '/soft64/altera/17.0/modelsim_ase/linuxaloem/vmap secureip /soft64/altera/17.0/modelsim_ase/secureip' returned exit code '0'.
Compiling verilog library 'secureip'...Executing cmd '/soft64/altera/17.0/modelsim_ase/linuxaloem/vlog -source -novopt -64 -work secureip -f /soft64/altera/17.0/modelsim_ase/secureip/.cxl.verilog.secureip.secureip.lin64.cmf' with output '/soft64/altera/17.0/modelsim_ase/secureip/.cxl.verilog.secureip.secureip.lin64.log' (Wed Jul 26 19:01:34 2017)...
compile_simlib[exe]: The command line '/soft64/altera/17.0/modelsim_ase/linuxaloem/vlog -source -novopt -64 -work secureip -f /soft64/altera/17.0/modelsim_ase/secureip/.cxl.verilog.secureip.secureip.lin64.cmf' returned exit code '7'.
Executing cmd '/soft64/altera/17.0/modelsim_ase/linuxaloem/vlog -source -novopt -64 -sv -suppress vlog-2583 -work secureip -f /soft64/altera/17.0/modelsim_ase/secureip/.cxl.systemverilog.secureip.secureip.lin64.cmf' with output '/soft64/altera/17.0/modelsim_ase/secureip/.cxl.verilog.secureip.secureip.lin64.log' (Wed Jul 26 19:01:34 2017)...
compile_simlib[exe]: The command line '/soft64/altera/17.0/modelsim_ase/linuxaloem/vlog -source -novopt -64 -sv -suppress vlog-2583 -work secureip -f /soft64/altera/17.0/modelsim_ase/secureip/.cxl.systemverilog.secureip.secureip.lin64.cmf' returned exit code '7'.
Reading the cxl log file - '/soft64/altera/17.0/modelsim_ase/secureip/.cxl.verilog.secureip.secureip.lin64.log' for warnings...
Generating the cxl result file - '/soft64/altera/17.0/modelsim_ase/secureip/.cxl.verilog.secureip.secureip.lin64.rpt' ...
compile_simlib: 2 error(s), 0 warning(s), 0.35 % complete
ERROR: [Vivado 12-3591] compile_simlib failed to compile for modelsim with 295 errors.
compile_simlib: Time (s): cpu = 00:00:37 ; elapsed = 00:01:02 . Memory (MB): peak = 2130.637 ; gain = 229.539 ; free physical = 7979 ; free virtual = 20594
ERROR: [Common 17-39] 'compile_simlib' failed due to earlier errors.
The full text is attached.
graces
It looks you're targetting Modelsim Altera edition rather than standard release. This is not supported.
For compatible 3rd party tools, please refer to Vivado release notes.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug973-vivado-release-notes-install-license.pdf
