naeim35
Vivado 2017.4 Modelsim verification License
Hi all,
I have created a TestBench which includes the AXI VIPs blocks using Vivado 2017.4. When I start SIMULATION the ModelSim runs but then I encounter with this ERROR message:
# Loading xilinx_vip.axi_vip_pkg
# Loading xilinx_vip.axi_vip_if_sv_unit
# Loading xilinx_vip.axi_vip_axi4pc
# Loading work.gash_axi_vip_1_0
# ** Error: (vsim-1) Unable to checkout verification license - testbench generation feature (randomize, randcase, randsequence, covergroup) is only supported with QuestaSim.
#    Time: 0 ps  Iteration: 0  Instance: /gash_tb File: ../../../../gash_tb.srcs/sources_1/new/gash_tb.sv
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./gash_tb_simulate.do PAUSED at line 9
My question is that if ModelSim PE 10.5a supports the AXI VIPs? Is there any solution for this problem?
Naeim
richardhead
You need to buy a full QuestaSim Licence to run an SV testbench with randomisation and coverage in it (which will cover the AXI VIPs)
naeim35
Thank you for the quick reply.
Br,
Naeim
