naeim35
Vivado 2017.4 Modelsim verification License
Hi all,
I have created a TestBench which includes the AXI VIPs blocks using Vivado 2017.4. When I start SIMULATION the ModelSim runs but then I encounter with this ERROR message:
# Loading xilinx_vip.axi_vip_pkg
# Loading xilinx_vip.axi_vip_if_sv_unit
# Loading xilinx_vip.axi_vip_axi4pc
# Loading work.gash_axi_vip_1_0
# ** Error: (vsim-1) Unable to checkout verification license - testbench generation feature (randomize, randcase, randsequence, covergroup) is only supported with QuestaSim.
#    Time: 0 ps  Iteration: 0  Instance: /gash_tb File: ../../../../gash_tb.srcs/sources_1/new/gash_tb.sv
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./gash_tb_simulate.do PAUSED at line 9
My question is that if ModelSim PE 10.5a supports the AXI VIPs? Is there any solution for this problem?
Best regards,
Naeim
richardhead
You need to buy a full QuestaSim Licence to run an SV testbench with randomisation and coverage in it (which will cover the AXI VIPs)
naeim35
Thank you for the quick reply.
Br,
Naeim
tflekan_ddc
I'm responding late to this but I've run into the same issue.
Richardhead, is it possible to modify the AXI VIP models to remove the randomization and coverage methods so that the models can be run in ModelSim?  At this point, I don't require randomization or coverage.
richardhead
@tflekan_ddc
Unlikely, as that is kind of their point (and you would have to ask Xilinx to do it). SV licences are usually broken down into separate langauge features and can be quite expensive.
If you're willing to give VHDL a go, OSVVM provides a full AXI4 + AXIS BFMs, and has other features to allow you roll your own coverage and randomisation if/when you need them. Plus its all open source and can be used on a single language VHDL licence without any extra costs incured over a base licence.
https://osvvm.org/
UVVM (https://bitvis.no/dev-tools/uvvm/) and VUnit (https://vunit.github.io/about.html) also provide open source AXI verification models, but they dont cover full axi4, only AXIS and AXI4-Lite
