Visitor runrun
Vivado 2019.1 error : when run $finish through task
Current I turn to use Vivado 2019.1
The simulation hang at $finish. This testbench would run successfully in old version e.g. 2018.1 and 2018.2
Because the simulation will end with 2-3 situations, I use "task" to do some end process to prevent repeat write code for ending. Below is example
initial begin
   $display("simulation end"):
   sim_end;
end
task sim_end;
begin
   $fclose(file_ptr1);
   $fclose(file_ptr2);
   $finish;
end
endtask
When simulation run to $finish, Vivado pop-up an warning window :
Vivado will hang ==> at bottom keep loading at "Current time : 79292ns ..." ==> cannot press "cancel"
If I press "OK" in pop-up window, another window pop-up
When "OK", it back to 1st warning window.  It is looping between 2 warning windows, if I just press "OK".
Finally, I found I need click "X" in warning windows.  Then simulation would stop successfull.
run: Time (s): cpu = 00:04:47 ; elapsed = 00:03:30 . Memory (MB): peak = 7932.930 ; gain = 0.000 ; free physical = 39796 ; free virtual = 126806
xsim: Time (s): cpu = 00:05:02 ; elapsed = 00:03:37 . Memory (MB): peak = 7932.930 ; gain = 0.000 ; free physical = 39796 ; free virtual = 126806
INFO: [USF-XSim-96] XSim completed. Design snapshot 'test_dl_behav' loaded.
INFO: [USF-XSim-97] XSim simulation ran for 100ms
launch_simulation: Time (s): cpu = 00:05:12 ; elapsed = 00:03:47 . Memory (MB): peak = 7932.930 ; gain = 0.000 ; free physical = 39796 ; free virtual = 126806
I don't know why it try to open something, I don't have any open file or read in task.
For testing I comment all code in task and only keep $finish.  The problem still appear.
task sim_end;
begin
// $fclose(file_ptr1);
// $fclose(file_ptr2);
   $finish;
end
endtask
Finally, I found move the "ending process code" out of task, the problem disappear.
initial begin
   $fclose(file_ptr1);
   $fclose(file_ptr2);
   $finish;
   sim_end;
end
task sim_end;
begin
   $fclose(file_ptr1);
   $fclose(file_ptr2);
   $finish;
end
endtask
In my testcase, there are 2-3 situations the simulation will stop.  I don't want repeatly write "end processing code" 2-3 times.
How to solve it, I think it is problem of 2019.1.
Re: Vivado 2019.1 error : when run $finish through task
Hi @runrun ,
This is a known issue and a CR is already in place for this issue. The only way to overcome this is to clicking on X to dismiss the dialog box and repeat until the dialog box goes away.
Visitor runrun
Anyone would help?
I google longtime and still cannot find the solution.
Hi @runrun ,
