pgigliotti_usac
Vivado 2020.1 - Some values not getting initialized during reset
I had just resolved one initialization error and ran into another. The signal Status_2_FRAM_data comes up as unknown. All other values in the reset come up as expected. When not in reset, the vector is set when certain cases are reached. Crazy.
if rising_edge(clk) then
if(reset = '1') then
read_count := 0;
compare_count := 0;
Status_2_Switch_wren <= '0';
Status_2_Switch_data <= (others => '0');
Status_2_FRAM_data <= (others => '0');
Switch_2_STATUS_Fifo_empty_CTR <= 0;
Switch_2_STATUS_rden <= '0';
switch_status_rdy <= false;
label_260_error <= (others => '0');
Status_2_Switch_error <= '0';
Read_SW_state <= idle;
Mux_error_detect <= '0';
enable_status <= (others => '0');
else
case Read_SW_state is
pgigliotti_usac
User error.  I had put the reset vector in the wrong process. Opening up elaborated design, pointed me to the issue.
pgigliotti_usac
