elevi
Vivado Behavioral Simulation getting stuck with Riviera Pro Simulator
Hi All,
I created a Vivado project and ran a simulation using the default Vivado simulator, everything works as expected (i.e the testbench and the waveforms)
When I switch the "Target Simulator" to "Riviera Pro Simulator" and run a behavioral simulation, Vivado is getting stuck and the linux terminal shows-
"[1]+ Stopped /scratch/Xilinx/Vivado/2018.2/bin/vivado"
My only option is to kill the process. There isn't any error message, and I can only see that the last stage was-
"Executing analysis and compilation step..." (please see image attached).
Techincal details-
- Vivado version- 2018.2
- Riviera Pro 2018.10.137.7135 built for Linux64
- I pre compiled all Xilinx libraries using "Tools>Compile Simulation Libraries" and I'm pointing the the appropriate "compile_simlib/riviera" in "simulation setting"
- I used the following tutorial to set up evryting-
https://www.aldec.com/en/support/resources/documentation/articles/1525
Can anyone please help me?
Thanks!
elevi
Solved!
I realized I had 2 versions of Riviera installed (2015 and 2018) and while the Xilinx pre compiled libraries was generated for 2018, the PATH launched Riviera 2015 which caused a mismatch.
After I fixed the paths and it works :)
graces
Does it work fine if you take the generated script and run it in standalone Riviera Pro?
elevi
Solved!
