aniello
Vivado ERROR: [XSIM 43-3238] Failed to link the design
Hi i want simulate a simply design in vivado, but when i try run simulation give me this message:
ERROR: [Runs 36-25] xelab application returned error(s). Please see 'C:/Users/Enrico/Desktop/vivado/project_1nello/project_1nello.sim/sim_1/behav/xelab.log' file for more details.
ERROR: [Common 17-69] Command failed: Failed to compile the design!
and in the log there is ERROR: [XSIM 43-3238] Failed to link the design.
i use vista, in the attachment there are the vhdl files
pratham
Have you googled it?
http://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-2103-3-Simulation-Failed-to-link-design/td-p/388205
Simulating other design doesnt mean all design could work on unsupported OS. I tried at my end and it runs seamlessly.
-Pratham
hj
Vista is not a supported OS. Please try on supported OS.
If you are not using latest version then try in 2013.4.
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
aniello
i use vivado 2013.2 and i have just simulate other design with vista
pratham
-Pratham
aniello
i have see this thread, but 2013.2 don't have the file settings64.bat, but the file settings32.bat, correct for my OS because it's 32 bit.
I must use vista because this isn't my workstation.
pratham
In that Case I Wont be able to help you further
-Pratham
debrajr
Please use a supported OS. It would be difficult to support your query as our tools are not tested on unsupported OS like Vista or Ubuntu and we cannot guarantee the performance/results.
Debraj
tsjorgensen
Found this too on supported OS.
Only the message "Failed to link the design" is given when trying to simulate a small design. Most likely there is a perfect logic reason why Vivado can't link the design but the important error here is that the error message is useless.
I used Vivado 2016.2.
xsim.dir/loop_goertzel16_tb_behav/obj/xsim_1.win64.obj:(.text+0x2a727): undefined reference to `_chkstk'
xsim.dir/loop_goertzel16_tb_behav/obj/xsim_1.win64.obj:(.text+0x4e3c7): undefined reference to `_chkstk'
collect2: ld returned 1 exit status
mus19f1a
I get the same problem in Vivado 2016.2.
Reason of the problem is the saved simulation waveform. If you remove the saved (probably last one) waveform from the project, simulation will again work.
I think that is the bug of vivado 2016.2.
mus19f1a
If you have the problem with running behaviour simulation on Vivado 2016.2,
There are a few thinks that works for me;
First of all remove all the waveforms from simulation sources.
1-) After getting the errors below, just run the simulation again, without any changes.
ERROR: [USF-XSim-62] 'elaborate' step failed with error(s)
it works for me.
2-) Close the project and delete the folders ".xil" , "project_name.cache" and "project_name.sim", then open your project and run the simulation.
Important: Before the deleting folders, don't forget to backup your special files in those folder
efpkopin
Anothing thing to try is to go to Project Settings => Simulation and, in there, change the 'Simulator Language' to 'Mixed'
I'm running Vivado 2016.1 and, while I have been successful in the past getting around this bug by deleting the .cache, & .sim folders, I was really stuck this time around (b/c I had the Simulator Language' set to VHDL).  Changing to 'Mixed' seems to have worked (for now!)
