Observer stmilch
Vivado Simulation in seperate Window
If I run the simulation in Vivado it runs inside Vivado. Especially on small screens I see less information than before running ISIM from PlanAhead. Is there a way to run ISIM as before to use the whole screen for the simulator (without the Vivado Frame)?
Re: Vivado Simulation in seperate Window
You can maximize the simulation window. Will that not help?
Deepika.
Deepika.
You can click on the float option on simulation window (top-right corner) to come out of Vivado frame.
See below snapshot:
Vinay
