hpoetzl
Voyager
Voyager
Vivado Simulator 2014.1 segfaults.
Attached is a small example which causes the Vivado Simulator to segfault.
ERROR: [XSIM 43-3316] Signal SIGSEGV received.
Printing stacktrace...
[0] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x511a6e]
[1] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x51f2c2]
[2] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x520956]
[3] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x53cf7e]
[4] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x53e736]
[5] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x53e8ae]
[6] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x53eccb]
[7] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x53e82e]
[8] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x53e8ae]
[9] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x54e905]
[10] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x54f22e]
[11] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x5161fc]
[12] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x5165bb]
[13] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x51041b]
[14] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x5dbd13]
[15] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x5d9495]
[16] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x5dbc28]
[17] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x5d9495]
[18] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x5bbd20]
[19] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x449794]
[20] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x452f58]
[21] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x44332e]
[22] /lib64/libc.so.6(__libc_start_main+0xed) [0x7f25923a832d]
[23] /opt/Xilinx/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x448b29]
Hope it helps,
Herbert
-------------- Yes, I do this for fun!
vuppala
Hi Herbert,
Thanks for providing the missing file.
I am able to workaorund the issue. Attaching the working design for your reference.
It is a Vivado Simulator bug and need to be fixed.
Vinay
vuppala
Hi Herbert,
Thanks for the testcase. But the file "vivado_pkg.vhd" is missing in the attached zip file. Attach it to investigate the issue.
Vinay
hpoetzl
Voyager
Voyager
Ah, sorry, it just defines the attributes.
You can grab it here: http://vserver.13thfloor.at/Stuff/XILINX/vivado_pkg.vhd
(for some reason the web interface does not allow to attach it, just says
 "The contents of the attachment doesn't match its file type.")
Best,
Herbert
debrajr
From a quick analysis, the issue looks to be related to the function call:
ones_v := count_bits_f(din, '1');
zeros_v := count_bits_f(din, '0');
in count_bits.vhd. Something the tool is not liking.
But as this is a crash we would be filing a bug request.
Debraj
vuppala
Hi Herbert,
Vinay
ashishd
Hi Herbert,
As Debraj mentioned that it is an issue with the function, if you slightly modify your architecture RTL_COUNT as shown below, you will be able to resolve the issue. I have written for loops separately outside the function.
architecture RTL_COUNT of count_bits is
attribute KEEP_HIERARCHY of RTL_COUNT : architecture is "TRUE";
begin
out_proc : process (clk)
variable ones_v : natural range 0 to 8;
variable zeros_v : natural range 0 to 8;
begin
if rising_edge(clk) then
-- ones_v := count_bits_f(din, '1');
for I in din'range loop
if din(I) = '1' then
ones_v := ones_v + 1;
end if;
end loop;
--zeros_v := count_bits_f(din, '0');
if din(I) = '0' then
zeros_v := zeros_v + 1;
end if;
end loop;
ones <= to_unsigned(ones_v, 4);
zeros <= to_unsigned(zeros_v, 4);
end if;
end process;
end RTL_COUNT;
Ashish
hpoetzl
Voyager
Voyager
Problem still exists in Vivado 2014.2.
Best,
Herbert
staceyrieck
To add to this problem, I saw something simmilar (Vivado 2014.1):
[0] /media/work/opt/Vivado/2014.1/lib/lnx64.o/libxsimverific.so(Verific::VeriTreeNode::StaticSizeSign(Verific::ValueTable*, Verific::VeriConstraint const*) const+0x1c) [0x7fde33807b8c]
[1] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x491cd2]
[2] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x4996b7]
[3] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x499deb]
[4] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x492269]
[5] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x49a296]
[6] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x499ef1]
[7] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x49142d]
[8] /media/work/opt/Vivado/2014.1/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x44) [0x7fde33929c84]
[9] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x49ad38]
[10] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x48b152]
[11] /media/work/opt/Vivado/2014.1/lib/lnx64.o/libxsimverific.so(Verific::VeriVisitor::TraverseArray(Verific::Array const*)+0x44) [0x7fde33929c84]
[12] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x49ad38]
[13] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x48a87d]
[14] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x459087]
[15] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x449654]
[16] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x452d11]
[17] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x44332e]
[18] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xfd) [0x7fde3236aead]
[19] /media/work/opt/Vivado/2014.1/bin/unwrapped/lnx64.o/xelab() [0x448b29]
I also had these two warnings:
WARNING: [VRFC 10-278] actual bit length 0 differs from formal bit length 12 for port addra
WARNING: [VRFC 10-278] actual bit length 0 differs from formal bit length 12 for port addrb
It turns out that one of the struct elements had a bit length of [-1:0] due to an error in the definition. This the signal to which the "actual bit length of 0" is referring.
This signal was connected to the block memory generator  IP core.
So if you see this segfault, check your warnings and make sure that your struct definitions are correct.
sylvainsgndt
@debrajr
I face the exact same error with Vivado 2015.3.  "ERROR: [XSIM 43-3316] Signal SIGSEGV received."  Is there any progress or more information about that bug that would get me out of that? Is there any kind of operation, structure that should be avoided in the simulation code that would prevent stumbling on that bug?
