Vivado Simulator Breakpoint in procdures
Hi, can any of you clever people in here help me. I'm struggling with debuging my testbench. It contains procedures because that makes things nice and tidy.
In ModelSim I was used to be able to insert breakpoints in these procedures.
Can that be done in the Vivado simulator??
I've attached a simple example to show what I'm trying to do.
Best Regards
Karsten
Re: Vivado Simulator Breakpoint in procdures
You can add break points using add_bp tcl command.
Refer to answer record http://www.xilinx.com/support/answers/63922.html for usage details.
Thanks,Vijay
Hi, I'm aware of the tcl command as well as the posibility from the GUI. But the question is if it is possible to add breakpoints in a procedure?
Please the the screenshot attached.
BR Karsten
At present, Vivado Simulator don't support adding break point inside procedure/task/function. It's under plan for future release.
--dhiRAj
Do  you know when this feature will be available ?
