francesco.lussignoli
Vivado crash after executing xsim.exe command
Hi all guys,
as mentioned above, after I run the xsim command to start a simulation, sometimes, vivado crash. I've seen that this behavior is reproducible if I do not click on the "background" button that is shown after the vivado gui is open.
The machine info are:
Vivado version: 2020.2
OS: Win10
RAM: 32 GB
I've tried to analyze the dmp file gerated and here the output:
Microsoft (R) Windows Debugger Version 10.0.17134.12 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\githg\Dante_plus\scripts\hs_err_pid589424.dmp]
User Mini Dump File: Only registers, stack and portions of memory are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Version 19042 MP (8 procs) Free x64
Product: WinNt, suite: SingleUserTS
19041.1.amd64fre.vb_release.191206-1406
Machine Name:
Debug session time: Tue Jun 22 13:54:08.000 2021 (UTC + 2:00)
System Uptime: not available
Process Uptime: 0 days 0:01:13.000
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(8fe70.903f8): Access violation - code c0000005 (first/second chance not available)
ntdll!NtGetContextThread+0x14:
00007ff9`f58eec54 c3 ret
0:001> !analyze
* Exception Analysis *
Use !analyze -v to get detailed debugging information.
*** ERROR: Symbol file could not be found. Defaulted to export symbols for librdi_wavedata.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for librdi_wavedatatasks.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for librdi_common.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for tcl85t.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for librdi_commontasks.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for librdi_simtcltasks.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for librdi_commonmain.dll -
*** ERROR: Module load completed but symbols could not be loaded for xsim.exe
*** ERROR: Symbol file could not be found. Defaulted to export symbols for jvm.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for awt.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for libboost_thread.dll -
Probably caused by : librdi_simbridge_kernel.dll ( librdi_simbridge_kernel!SimBridge::WdbEventBlock::addBlock+29 )
Followup: MachineOwner
0:001>
rax=0000bd5fdda1f6a9 rbx=000001d8a2c60270 rcx=0000000000000000
rdx=000001d8959009a0 rsi=000001d8959009a0 rdi=0000000000000000
rip=00007ff9a6881049 rsp=0000000a99ef9cb0 rbp=0000000000000000
r8=0000000a99ef9d40 r9=0000000000000018 r10=0000000000000000
r11=0f01800000000000 r12=0000000000000001 r13=00007ff9a68a8e50
r14=000001d89ebd0590 r15=0000000a99ef9d40
iopl=0 nv up ei pl nz na pe nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010202
librdi_simbridge_kernel!SimBridge::WdbEventBlock::addBlock+0x29:
00007ff9`a6881049 83794400 cmp dword ptr [rcx+44h],0 ds:00000000`00000044=????????
Anyone can help me fix this error?
