Vivado crashes when creating new SystemVerilog file
I created a new file to insert some simulation related code to an existing design.
I suppose this bug is not really reproducible, but there is a Java stack dump
which hopefully helps Xilinx to improve their product and to avoid those crashes in
future.
# Xilinx Vivado v2017.4 (64-bit)
# SW Build: 2086221 on Fri Dec 15 20:54:30 MST 2017
# IP Build: 2085800 on Fri Dec 15 22:25:07 MST 2017
# Current time: Tue Feb 27 15:14:35 CET 2018
# Process ID: 70238
# User: haver
# OS: Red Hat Enterprise Linux Workstation release 6.4 (Santiago)
# This report is an indication that an internal application error occurred.
# This information is useful for debugging. Please open a case with Xilinx.
# Technical Support with this file and a testcase attached.
java.lang.NullPointerException
at ui.views.T.a.an.a(SourceFile:415)
at ui.data.j.a.a(SourceFile:202)
at ui.data.j.a.bQp(SourceFile:150)
at ui.views.T.a.Z.a(SourceFile:397)
at ui.views.T.a.Z.gxB(SourceFile:314)
at ui.views.T.a.al.finished(SourceFile:3481)
at ui.frmwork.w.run(SourceFile:195)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at ui.frmwork.b.d.dispatchEvent(SourceFile:76)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Hi @haver,
Can you please share a test case to reproduce this issue at our end. Also, can you please make sure that you are using supported OS with vivado 2017.4.
For information on supported OS please refer the below Answer Record:
https://www.xilinx.com/support/answers/54242.html
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
Hi @haver
I guess you need to upgrade your OS from RHEL 6.4 to at least 6.6 or 6.7.
Would you refer the following support OS information ?
AR #54242
[Note]
It doesn't make sense in AR #54242.
Could Xilinx employee make sure it ?
RHEL 6.6 - 6.9
CentOS 6.7 - 6.9
Best regards,
Thanks for making me aware that I was using an old OS installation. I will talk to our IT folks if they can update the OS level.
