paebbels
Vivado doesn't properly escape paths with spaces
according to AR #52981, the problem was solved. However, I can reproduce the issue in Vivado 2017.x!
Any comments from Xilinx how a solved bug can occur again?
In my case, it's a WCFG file conaining spaces, that can't be loaded after saving and adding it to the project.
Kind regards
    Patrick
graces
I ran a test at my end. If the .wcfg filename contains space, it cannot be loaded automatically when launching simulation. However, it can still be opened successfully after simulation is launched.
The fix in the mentioned AR mainly deals with the corrupt path separator by adding curly braces around --view option in xsim command. It looks when space is found, it's still interpreted as the end of filename.
I'll provide the feedback to the dev team. Thanks for reporting this to us.
Currently please avoid using spaces.
graces
