Vivado example design simulation error
I recently updated from Vivado 2018.2 to Vivado 2018.2.2 in Windows 10. The example base design used is a Base Zynq design (with a AXI GPIO and AXI BRAM). Before the version update, this example design worked using XSim. After the update, a new project was created and the example design fails simulation with the following error :
INFO: [VRFC 10-163] Analyzing VHDL file "PROJECT_PATH/project_6/project_6.ip_user_files/bd/base_zynq/ip/base_zynq_axi_gpio_0_0/sim/base_zynq_axi_gpio_0_0.vhd" into library xil_defaultlib
ERROR: [VRFC 10-149] 'axi_gpio' is not compiled in library axi_gpio_v2_0_19 [PROJECT_PATH/project_6/project_6.ip_user_files/bd/base_zynq/ip/base_zynq_axi_gpio_0_0/sim/base_zynq_axi_gpio_0_0.vhd:57]
INFO: [VRFC 10-307] analyzing entity base_zynq_axi_gpio_0_0
ERROR: [VRFC 10-1504] unit base_zynq_axi_gpio_0_0 ignored due to previous errors [PROJECT_PATH/project_6/project_6.ip_user_files/bd/base_zynq/ip/base_zynq_axi_gpio_0_0/sim/base_zynq_axi_gpio_0_0.vhd:59]
INFO: [VRFC 10-240] VHDL file PROJECT_PATH/project_6/project_6.ip_user_files/bd/base_zynq/ip/base_zynq_axi_gpio_0_0/sim/base_zynq_axi_gpio_0_0.vhd ignored due to errors
where PROJECT_PATH is path of my project locally. Synthesis of the project seem to complete fine. It looks like AXI_GPIO simulation libraries need to be re-compiled. I believe this has to be done automatically for Xsim and manually for 3rd party simulation tools after a version update. Could anyone explain why and suggest solutions for the problem ?
Paul
回复: Vivado example design simulation error
I don't think the problem will be solved until a new Vivado version is released or at least a patch. However, I managed to work around the problem. I cannot remember all the details but here is what I did :
In Settings of Vivado GUI, you can find IP project setting. Disable the option " Use Precompiled IP simulation libraries ". I think this change is sufficient but if it doesn't work, go to Simulation in IP project setting. Go to Advanced and disable incremental compilation.
Hope that works for you.
Did you upgrade the IPs and re-generate the output product?
Thanks for getting back on this question.
I didn't regenerate the IP because there was no report for outdated IP's in the project. I believe this was due to a minor update from version 2018.2 to 2018.2.2. Also, note that synthesis worked fine without errors. Is there a way to force an update for simulation libraries?
I also created a new project with example template from Xilinx (Base Zynq design with AXI GPIO and AXI BRAM) and still encountered the same problem.
I can reproduce the failure with the Base Zynq example design. I agree something is broken in the pre-compiled Xsim libs.
I'll file a CR so that dev team can investigate and fix it.
Thank you for reporting this issue.
Visitor blamberg_
is the problem solved now? I need the axi_gpio in 2018.2.2 and have the same problem.
Visitor blamberg_
Thank you. I disabled both options and vivado works fine.
