ultrascaleaddict
Vivado, export_simulation and modelsim 10.5c
First of all the context:
  - I am using Vivado 2018.3 + Modelsim 10.5c
  - I am targeting a Kintex KU115
  - I am trying to simulate the gtwizard ultrascale example design
  That being said, I used the export simulation function which iis given here below:
export_simulation  -lib_map_path "/path_to/CompileSimLib" -absolute_path -force -directory "/path_to/vivado/trial/gtwizard_ultrascale_0_ex/simuFolder" -simulator modelsim  -ip_user_files_dir /path_to/vivado/trial/gtwizard_ultrascale_0_ex/gtwizard_ultrascale_0_ex.ip_user_files" -ipstatic_source_dir /path_to/vivado/trial/gtwizard_ultrascale_0_ex/gtwizard_ultrascale_0_ex.ip_user_files/ipstatic" -use_ip_compiled_libs
When I try to launch the simulation from my Linux terminal (.sh file) I get the following error:
# 10.5c
# vsim -c -do "do" {simulate.do} -l simulate.log
# Start time: 15:04:52 on Apr 01,2019
# ** Error (suppressible): (vsim-19) Failed to access library 'work' at "work".
# No such file or directory. (errno = ENOENT)
# Error loading design
# End time: 15:04:52 on Apr 01,2019, Elapsed time: 0:00:00
# Errors: 1, Warnings: 0
But when I launch "do simulate.do" from Modelsim everything works fine.
So where am I missing to point to the work library?
Thank you for your help.
ultrascaleaddict
I've just found the problem! Actually there are 2 bugs in the generated compile.do and .sh files from Vivado:
1- In compile.do , the "work" mapping is missing --> Add vmap work modelsim_lib/work
2- In the .sh file: in the simulate function, the command vsim -64 -c -do "do {simulate.do}" -l simulate.log is erroneous, replace it by vsim -64 -do simulate.do -l simulate.log and everything will be fine.
graces
I'd expect running the .sh script will source compile.do, elaborate.do and simulate.do sequentially.
Generally in compile.do, vlib command is specified to create work directory in the current directory. You may want to cross check the log files and target directories.
BTW, the compatible modelsim version with Vivado 2018.3 is 10.6c.
ultrascaleaddict
Hello Graces and thank you for your quick reply.
First of all regarding the version, yes I am working on getting the latest version (10.6e).
Any way, I added vlib work and now I get the foolowing error:
# Start time: 10:24:37 on Apr 02,2019
# ** Note: (vsim-3812) Design is being optimized...
# ** Error (suppressible): (vopt-19) Failed to access library 'work.{simulate' at "work.{simulate".
# End time: 10:24:37 on Apr 02,2019, Elapsed time: 0:00:00
# Errors: 2, Warnings: 0
Please find here attached the files I generated from Vivado 2018.3 (export simu feature).
regards,
graces
Did you edit the compile.do and simulate.do? Why is there a duplicate creation of library work?
vlib modelsim_lib/work
vlib modelsim_lib/msim
vlib modelsim_lib/msim/xil_defaultlib
vlib modelsim_lib/msim/work
vmap xil_defaultlib modelsim_lib/msim/xil_defaultlib
vmap work modelsim_lib/msim/work
What are the original generated scripts like?
ultrascaleaddict
These ARE the original scripts Graces obtained as I said by export_simulation by Vivadoo.
Is there a bug I am not aware of?
graces
I gave it a try at my end (2018.3 + Modelsim 10.6c) but didn't observe the same vlib commands in compile.do & simulate.do.
Attached the scripts for your reference.
ultrascaleaddict
Hello Graces,
Same here, I just got the modelsim 10.7c. I gave it a try and I have the same commands as you....But unfortunately, the generated .sh file is still not working: I still have te same error message.
Did that work for you? the .sh file?
Rgds,
ultrascaleaddict
graces
I can source the .sh successfully "as is". There's no need to map the work library as the logical 'work' library is not loaded in vsim command, instead, 'xil_defultlib' is referenced.
Attached are the log files.
ultrascaleaddict
Still not working for me. So i think i am gonna stick to my solution. Thank you anyway.
Rgds
d2d
@ultrascaleaddict  please share the link for downloading ModelSim 10.7c, becasue I also need this release of modelSim
