Vivado path issues
Using a VHDL package with global project options and scripts to simulation and implementation I find the following path issues.
Environment :
Ubuntu 16.04 LTS | ~$ echo $HOME => /home/daniel
Vivado 2017.4
First try: shorthand.
CONSTANT prog : STRING := "~/blackbox/Po/Files/IntDemo.mem";
Results:
Simu script
ERROR: [VRFC 10-2551] failed to open VHDL file '~/blackbox/Po/Files/IntDemo.mem' in mode 'r' [/media/Trabajo/ProyectosPersonales/P20180037/FPGA/Srcs/MCU/LRAM.vhd:36]
Build script
Build.tcl finalizado en 217 seg
Second try: environment variable
CONSTANT prog : STRING := "$HOME/blackbox/Po/Files/IntDemo.mem";
Result:
Simu script
ERROR: [VRFC 10-2551] failed to open VHDL file '$HOME/blackbox/Po/Files/IntDemo.mem' in mode 'r' [/media/Trabajo/ProyectosPersonales/P20180037/FPGA/Srcs/MCU/LRAM.vhd:36]
Build script
ERROR: [Synth 8-3302] unable to open file '$HOME/blackbox/Po/Files/IntDemo.mem' in 'r' mode [/media/Trabajo/ProyectosPersonales/P20180037/FPGA/Srcs/MCU/LRAM.vhd:36]
Third try: full path
CONSTANT prog : STRING := "/home/daniel/blackbox/Po/Files/IntDemo.mem";
Results:
Simu script
Simulation GUI running
Build script
There's already a CR on this topic. Currently a path with environment variable is not recognized in Xsim.
Correction:
A path with environment variable is not recognized in Xsim or in implementation tool flow.
A path with shorthand is not recognized in Xsim.
So, I can conclude that Xilinx is using two different parsers; one for the implementation flow, another for the simulation flow. and there are problems in both flows.
