naeim35
Vivado simulator fails to run in Linux System
Hi all,
I am tring to run Vivado 2018.2 simulation in the Linux system but I encoutered with the following ERROR;
INFO: [SIM-utils-54] Inspecting design source files for '...' in fileset '...'...
INFO: [USF-XSim-97] Finding global include files...
basic_string::substr: __pos (which is 136) > this->size() (which is 85)
while executing
"list_property $file_obj"
(procedure "xcs_is_bd_file" line 23)
invoked from within
"xcs_is_bd_file $vh_file"
("foreach" body line 14)
invoked from within
"foreach vh_file $vh_files {
set vh_file_obj {}
if { [info exists a_sim_cache_all_design_files_obj($vh_file)] } {
set vh_file_obj $a_sim_..."
(procedure "usf_get_include_file_dirs" line 30)
invoked from within
"usf_get_include_file_dirs $global_files_str $prefix_ref_dir"
(procedure "usf_get_other_verilog_options" line 46)
invoked from within
"usf_get_other_verilog_options $global_files_str other_ver_opts"
(procedure "usf_get_files_for_compilation_behav_sim" line 29)
invoked from within
"usf_get_files_for_compilation_behav_sim $global_files_str"
(procedure "::tclapp::xilinx::xsim::usf_get_files_for_compilation" line 16)
invoked from within
"::tclapp::xilinx::xsim::usf_get_files_for_compilation global_files_str"
(procedure "usf_xsim_setup_simulation" line 80)
invoked from within
(procedure "tclapp::xilinx::xsim::setup" line 19)
invoked from within
"tclapp::xilinx::xsim::setup { -simset <project_name>_sim -mode behavioral -run_dir /home/<project_directory>..."
ERROR: [Vivado 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
ERROR: [Common 17-39] 'launch_simulation' failed due to earlier errors.
 Is there any solution for this problem?
Thank you in advance for your help!
Naeim
graces
Is it a project specific issue or seen in every simulation?
What is your OS version?
naeim35
I have the same problem for the other projects as well.
here is my OS info:
NAME="Ubuntu"
VERSION="18.04.1 LTS (Bionic Beaver)"
Br,
Naeim
shameera
Hi @naeim35 ,
What about example designs exported with Vivado Installation ? Do you see the same issue for example designs too ?
If so, can you please share the vivado.log as it seems to be machine specific issue to me,
