Vivado simulator - strange error
Hello everybody,
I am trying to simulate my design, but the simulator returns some strange error, which doesn't tell me much:
[VRFC 10-664] expression has 28 elements : expected 32 [/wrk/2015.3/nightly/2015_09_28_1368829/data/vhdl/src/unisims/primitive/SIM_CONFIGE2.vhd:374]
[XISIM 43-3322] Static elaboration of top level Verilog design unit(s) in library work failed.
The design can be implemented and runs on the fpga, so i assume there are no syntax errors in my code.
Any idea what could be the problem.
Klemen
I see, thank you,
What i found was:signal idcode_reg1  : v32_a (3 downto 0) := (others => TO_STDLOGICVECTOR(DEVICE_ID));
It seems the problem is my ICAPE2_inst:
ICAPE2_inst : ICAPE2
    generic map ( DEVICE_ID => X"3651093", ICAP_WIDTH => "X32", SIM_CFG_FILE_NAME => "None" )
    port map (
        O => icap_o_swapped,    -- 32-bit output: Configuration data output bus
        CLK => icap_clk_manual, -- 1-bit input: Clock Input
        CSIB => icap_ce,        -- 1-bit input: Active-Low ICAP Enable
        I => icap_i_swapped,    -- 32-bit input: Configuration data input bus
        RDWRB => icap_write     -- 1-bit input: Read/Write Select input (RDWR_B = 0: Write control, RDWR_B = 1: Read control)
This is a copy of vhdl instantiation template in UG768. Then I changed the DEVICE_ID => X"3651093" to DEVICE_ID => X"03651093" and error was gone. :)
Thank you for your help,
Klemen
Hi @fogl,
This happens when there is a mismatch between the parameters that you have provided and the parameters that have been coded in the primitive. I think you can bring this error down to a warning.
Also, please post your code here.
Nupur
Give kudos if it led you to the solution, accept as solution if it resolved your query.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
Hi @fogl,
Just have some doubts.
Are you declaring any data type of higher length and assigning it to a lower length datatype?
for e.g;
a: signal std_logic_vector (31 downto 0);
b: signal std_logic_vector (27 downto 0);
b<='1' & a;
Which Vivado version you are using?
Can you please check with Vivado 2015.3 and let us know.
Is it an error or warning message?
Are you getting any error in simulation?
Arpan
Arpan
@fogl
Looks like width mismatch assignment to me, check RTL if any top-level generic is changing the width of the statement signals.
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
@fogl,
Which vivado version are you using? Also does your project contain Mixed lanuage (verilog and VHDL) coding?
--Syed
I am using Vivado 2015.3. The simulation is set to mixed. My stimulus and also the code is written in vhdl. I think i had to select mixed because BRAM simulation model is written in verilog.
SIM_CONFIGE2.vhd that error points to was not written by me.
It could be that i am declaring data type of higher length and assigning it to a lower length datatype as suggested (a: signal std_logic_vector (31 downto 0); b: signal std_logic_vector (27 downto 0); b<='1' & a;) but i can not see/find where - the message does not pinpoint to any line in my code. It also seems strange that the design can be implemented and programmed to fpga - this is why i assumed no syntax errors.
This is a larger project with several files. I have no idea which part of the code could cause this - i assume the whole code would not help.
Hi @fogl
Please post SIM_CONFIGE2.vhd, since the error message points to this file, line 374 as stated in:
This will enable us to review the possible width mismatch.
Tushar
I tried to find this file, but it seems it is not there. I can not even find the folder "wrk".
I am using linux.
find / -name "wrk" -type d
find / -name "nightly" -type d
returns nuthing.
Hi @fogl,
Try to look for the file in this folder:
C:\Xilinx\Vivado\2015.3\data\vhdl\src\unisims\primitive
Nupur
Nupur
I see, thank you,
    port map (
Klemen
