Visitor dgutierr
Vivado simulator with DPI does not work in Debian9
When I Run the demo that ships with Vivado simulator "simple_import" to test DPI-C in Debian 9 (or perhaps any linux distribution that uses GNU GCC 6) The simulation fails with the error below:
sh run.csh
Multi-threading is on. Using 46 slave threads.
Running compilation flow
Done compilation
Done linking: "/mathworks/home/dgutierr/Documents/tmp/simple_import/xsim.dir/xsc/dpi.so"
INFO: [VRFC 10-2263] Analyzing SystemVerilog file "/mathworks/home/dgutierr/Documents/tmp/simple_import/file.sv" into library work
INFO: [VRFC 10-311] analyzing module m
Vivado Simulator 2017.2
Copyright 1986-1999, 2001-2016 Xilinx, Inc. All Rights Reserved.
Running: /mathworks/hub/share/apps/HDLTools/Vivado/2017.2-mw-0/Lin/bin/unwrapped/lnx64.o/xelab work.m -sv_lib dpi -R
WARNING: [XSIM 43-3431] One or more environment variables have been detected which affect the operation of the C compiler. These are typically not set in standard installations and are not tested by Xilinx, however they may be appropriate for your system, so the flow will attempt to continue.  If errors occur, try running fuse with the "-mt off -v 1" switches to see more information from the C compiler. The following environment variables have been detected:
    LIBRARY_PATH
Starting static elaboration
Completed static elaboration
Starting simulation data flow analysis
Completed simulation data flow analysis
Time Resolution for simulation is 1ps
Compiling module work.m
/usr/bin/ld: xsim.dir/work.m/obj/xsim_2.lnx64.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: Nonrepresentable section on output
collect2: error: ld returned 1 exit status
ERROR: [XSIM 43-3238] Failed to link the design.
I think Vivado Simulator is not compiling the binaries with -fPIC , is there any way to force it to use this flag?, or force it to use the distribution compiler? (I believe it uses CLang)
Tags (2)
Re: Vivado simulator with DPI does not work in Debian9
HI @dgutierr,
The Debian9 is unsupported OS with Vivado 2017.2. Please refer the below user guide page#8 for the supported OS information:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug973-vivado-release-notes-install-license.pdf
Hence can you please try using supported OS and try passing “-cc gcc”  to xelab and see if this helps.
Thanks & Regards,
Sravanthi B
Please mark the appropriate post as an answer "Accept as solution" in case it helps to resolve your query.
Thanks & Regards,
Sravanthi B
