Vivado2014.4 Modelsim, how to recompile file?
I use vivado2014.4 and Modelsim to do simulation.
When I update a source file, I go to 'xil_defaultlib' and 'recompile' the file in Modelsim, but this still not work when I 'restart' the simulation.  So for now I have to quit Modelsim and reopen simulation from vivado.
How can I update the simulation in Modelsim.
Regards.
Re: Vivado2014.4 Modelsim, how to recompile file?
Hi @marsmoon
Did you try restarting the simulation from Vivado GUI?
Thanks,Vijay
I have a similar problem.
VIVADO does not work correctly with Modelsim  and Questasim.
Generally, VIVADO does not work adequate in many aspects, and does not change for the better. No matter what kind of release, this program is not completed yet
