[Vivodo 2019.2][Non-Project Simulation] duplex definition result unexpected
Hi Everyone,
I have a design FDCEx8 as follows,
module FDCEx8(
    input wire [7:0] D,
    input wire E,
    input wire C,
    input wire R,
    output wire [7:0] Q
    FDCE #(
        .INIT                   (1'b0),     // Initial value of register, 1'b0, 1'b1
                                            // Programmable Inversion Attributes: Specifies the use of the built-in programmable inversion
        .IS_CLR_INVERTED        (1'b0),     // Optional inversion for CLR
        .IS_C_INVERTED          (1'b0),     // Optional inversion for C
        .IS_D_INVERTED          (1'b0)      // Optional inversion for D
    U[7:0] (
        .Q                      (Q[7:0]),   // 1-bit output: Data
        .C                      ({8{C}}),        // 1-bit input: Clock
        .CE                     ({8{E}}),        // 1-bit input: Clock enable
        .CLR                    ({8{R}}),        // 1-bit input: Asynchronous clear
        .D                      (D[7:0])    // 1-bit input: Data
endmodule
When I call this module in TOP design as follows,
`timescale 1ns / 1ps
module DUT_TOP(
    input wire [7:0] D,
    input wire E,
    input wire C,
    input wire R,
    output wire [7:0] Q
    FDCEx8 FDCEx8_U0(
        .D  (D),
        .E  (E),
        .C  (C),
        .R  (R),
        .Q  (Q)
    FDCEx8 FDCEx8_U1(
        .D  (D),
        .E  (E),
        .C  (C),
        .R  (R),
        .Q  (Q)
endmodule
When I do the simulation in Vivado 2019.2, the result will be unexpected of Q of FDCEx8.
Here, when I only call one the FDCEx8 module in TOP design, the simulation result will be expected.
But, when I call one the FDCEx8 module two times in TOP design,including FDCEx8_U0 and FDCEx8_U1,
For example, when I send D is 8'b0101_1010 to FDCEx8. The Q of FDCEx8 data will be 8'b0zzz_zzzz.
When I only call one the FDCEx8 module in TOP design. The Q of FDCEx8 data will be 8'b0101_1010.
I don't know what's happened? And the attached file is the project file.
Please help me understand.
Thank you.
  Tried with vivado latest version reported issue not observed during simulation.
  Please try with latest vivado version.
Ranganath
Hi Rangant,
I'll try the newest version.
When I have any results, I'll report here.
Thank you.
