WARNING: File descriptor (-19999) passed to $fwrite is not valid
Hi all,
I'm running a simulation where I write some values to a .txt using $fwrite, and I'm getting this WARNING:
I've checked this solution with no luck: https://www.xilinx.com/support/answers/47891.html
This is my $fopen line:  file = $fopen ("a.txt", "w");
And this is my $fwrite line: $fwrite (file, "HELLO");
It does not matter what I put in those two functions, it always gives me that warning.
I think the problem is that I'm closing the file ( $fclose(file); )  before the simulation ends, so that ISIM is trying to write in a closed file.
So, how can I place $fclose(file); just at the end of the simulation?
The path where the project is has no blank spaces nor strange characters ...
Can you please help me with this?
Please find attached the testbench I'm running.
Re: WARNING: File descriptor (-19999) passed to $fwrite is not valid
Hi @kardec,
Yes the main reason of this warning is the statement  $fclose(file);  Because as per your TB you are closing the file after 950 ns. If you are simulating more than 950 ns then this warning occurs as there is no file open to write. So, simulate the design for 950 ns then this warning will not occur.
Thanks & Regards,
A.Shameer.
Hi @kardec,
Thanks & Regards,
A.Shameer.
