Waveform Viewer redocks when relaunching
Is there a way to prevent the Waveform Viewer from re-docking itself when a simulation is relaunched? I run a simulation and undock and move the viewer to a separate monitor. If I relaunch I need to do it again. And again. Etc.
Thanks!
Professor
Professor
First, what version of ISIM are you using?
What Operating system?
32 or 64 bit version of ISIM?
When I do this, I have found that using the Re-Launch button in the Wave Viewer window does not give me this behavior, while using the Re-Launch button on the main ISIM window does.
I'm currently using Windows XP Pro 32-bit and ISIM from ISE 14.7
-- Gabor
Please refer this AR: http://www.xilinx.com/support/answers/34549.htm
Yash
Wow! Rookie mistake not including my system info! Sorry!
Vivado 2014.2
Windows 7 64-bit
I don't see a relaunch button on the waveform window and the referenced AR is for ISIM (I don't see the same options).
