What does this timedelay code mean?
Hi, here's a simple piece of code and the resulting waveform puzzles me a little bit. Please help.
module test_tb;
    reg a;
    wire a2, b2, out2;
    always begin
        a = 0;
        #5;
        a = ~a;
        #5;
    end
    assign a2 = a;
    assign b2 = 1;
    and #(5, 7) g2(out2, a2, b2);endmodule
Why red line in the middle?
Why out2 keeps being 1, instead of keeping in line with a2, after 10 time units (as I measure)?
How does #(5, 7) work?
Thank you!
Hi @cmpt_design,
I believe that it is a rsie fall time setting e.g. from the language reference manual:
or #(4, 3) ig (o, a, b); /* or gate called ig (instance name); rise time = 4, fall time = 3 */
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Hi @cmpt_design,
As specified by @amaccre, those delays correspond to the gate level delays.
In general, it has three delays Rise, fall and turnoff.
The rise delay is a delay with a gate output transition to 1 from other values (0, x, z).
The fall delay is a delay with a gate output transition to 0 from other values  (1, x, z).
The Turn-off delay is a delay with a gate output transition to z from other values  (0, 1, x).
If you specify only one delay then it considers same for all Rise, fall and typical.
Ex:- and #1 b2(out2,a2,b2) --> Rise=1, Fall=1, Turnoff=1;
If you specify two delays then it considers for Rise and fall alone.
Ex:- and #(1,2) b2(out2,a2,b2) --> Rise=1, Fall=2;
If you specify three delays then it considers for all Rise, fall and typical delays.
Ex:- and #(1,2,3)  b2(out2,a2,b2) --> Rise=1, Fall=2, Turnoff=3;
Thanks & Regards,
A.Shameer
Yeah, that makes good sense.
But I'm still confused as to the red line at the first 10 time units
and the result's remaining unchanged
Yeah, that makes good sense, rise & fall delay.
But I'm still confused as to the red line during the first 10 time units
and the result's remaining unchanged.
